cf-6004 signal conditioning
im working on connecting simple sensors [temp, pressure etc] to a pda with the CF-6004,
does anyone know which signal conditioning unit would be best suited to this?
also with the conditioning unit what extra hardware do i require [so far i know i need the DAQ card, shielded cable an terminal connector block]
thanks alot
andy
(4,340 Views)
Hi Andy,
The product CF-6004 will require you to purchase the cable and connector block.
As far as the signal conditioning hardware you need it's fully dependand on the form factor, sample rates and resolution you require, I'd suggest looking at https://www.ni.com/en/shop/data-acquisition.html especially the compactDAQ devices.
I hope this answers your questions, if you have any more information regarding the above dependencies please post here and I will try and help you out some more,
(4,291 Views)
Hi Andy,
It has come to my attention that we don't actually sell any signal conditioning products for the CF-6004, please ignore my previous post. Apologies for the mistake on my part.
(4,259 Views)
