I'm outputing a waveform via DAQmx. The waveform is a decaying sine wave over a variable time period, normally 10 seconds or a number of minutes. I display the waveform to be output on a graph display but I would like to give the user an indicator as to the progress of the output. Is it possible to get a property node to tell how many seconds into the total output you are?
I have looked at the properties and can find nothing that looks like it could do this.
I use the 'DAQmx Task Is Done.vi' to check when it has finished within a loop.
Thanks in advance.
