clear sound waveform
Any idea how to clear the waveform graph at the beginning before i going to capture the new waveform??
Simon
(3,605 Views)
Wire an empy array to a local of the graph before you acquire again.
André
André (CLA, CLED)
(3,596 Views)
Hi André,
I try it before, it comes out error the type of sources is 1D array of double and type of sink is 1D array of waveform.
regards,
(3,593 Views)
Try creating the constant from the waveform wire.
André
Message Edited by andre.buurman@carya on 09-04-2007 01:21 AM
André (CLA, CLED)
(3,592 Views)
I know need to create a empty array to clear the graph, but still fail.
(3,585 Views)
I did the following:
1. Create local from graph indicator
2. Right click local and create constant.
or
2. Right click wire between DAQ and graph and create constant.
Result:
André
Message Edited by andre.buurman@carya on 09-04-2007 01:47 AM
André (CLA, CLED)
(3,581 Views)
I get it already. Thanks alot  ..
regards,
(3,574 Views)
