communication with digiforce over rs232
Hello!
I'm trying co communicate with digiforce 9310 over rs232 and i can't get any response. It works fine when I'm using their (Burster's) original program. Since now I never had problems with serial communication. I think the problem is that both sides have master status at start point.. and I don't know how to specify a slave station. any suggestion?
(3,568 Views)
Are you communicating using NI-VISA or the Windows API? Do you get any specific errors? I suggest trying hyperterminal to see if you can get a response from there. You could also download portmon (a serial port monitor), to see what the Burster's program is sending to the port, and perhaps that will give you an idea of what to do. Hope this helps.
Ebele O.
(3,542 Views)
I chacked out some threads about using rs232 and already solved the problem. anyway..thank you for your suggestions about using portmon. .useful reply.
(3,532 Views)
Hello i have the same trouble to communicate a digiforce via rs232 and
could you explain me what you did to solve that problem please?
(3,156 Views)
Hi montañanevada,
could you please specify, if you are getting any errors, so we could try and find out, where the actual issue is taking place?
Thanks and have a great day!
Jano
(3,137 Views)
