compactdaq ethernet shared by 2 host PCs
Is it possible to access independtly 2 digital modules in a NI cDAQ-9188 ethernet compactdaq chassis via 2 different host PCs ? In other words: is it possible to share a NI cDAQ-9188 ethernet compactdaq chassis with two host PCs ? Laurent
(3,043 Views)
Accepted by topic author McFly
Hey,
No, you cannot acces it from more then one PC, as described in this KB.
You could think about creating an exectuable which reads the data from the cDAQ and then shares it over the network for other PCs.
Christian
(3,035 Views)
Thanks for the prompt and precise reply. Sorry I did not notice there was a answer in a KB (I checked only on the forum).
Laurent
(3,030 Views)
