connect 9 ADXL103 to BNC-2090?
hi,
Im building a six-axis of freedome GYROCUBE using 9 single access accelerometers ADXL103 http://www.analog.com/UploadedFiles/Data_Sheets/ADXL103_203.pdf form Analog Devices company, each sensor has an analog output +/- 1.7V per gee. could you please tell me how do i connect the outputs of the accelerometers (single wire) to BNC-2090 which is a product of yours.. do i need to have extar filters or external circits..?
do i have to use co-axial (shielded) cables to input the signals?
thanks in a dvance for your help
rgards
Mohado
Message 1 of 1
(2,883 Views)
