connect terminals and disconnect terminals APIs
Hi John,
I do know there are better methods to do edge counting than using the Connect Terminals function but as i said i need to "test" the Connect Terminals API through some means. If you have a better example through which i can test the API as well as understand its usefulness, I will be grateful if you can provide me the sample code in CVI.
Priya.
Message 11 of 11
(829 Views)
