connecting NI PCI 6250 to laptop OR USB equivalent of PCI 6250
Hi All,
I want to connect a PCI 6250 card to the laptop. Is there any way I can do it?
Is there any USB equivalent for it?
Thanks in advance,
(4,191 Views)
The USB equivalent would be the NI USB-6351 since the 62xx USB devices are scheduled for obsolescense.
Christian
(4,188 Views)
Thanks Christian, for your reply.
Actually, I will be using this DAQ for the first time. Can you please suggest a method to interface an SCSI 68 pin to the USB 6351? Are there SCSI ports already available (as in PCI 6250)  or do I have to put additional connectors?
Khalid
(4,182 Views)
I assume you mean SCB-68 and not SCSI 68. The USB-6351 has a direct PinOut via Srew Terminals.
Christian
(4,176 Views)
No I was hoping to connect a device which has an SCSI 68 pin-out. Previously, I used to connect the device to my computer by using a PCI 6250 card and an adpater(http://h30094.www3.hp.com/product/sku/1780665/mfg_partno/F2N1066-03-T&jumpid=in_r3924_us%2Fen%2FSASS...)
Any ideas ?
(4,174 Views)
Accepted by topic author kmirza
As I said the USB-6351 has Srew Terminals, so there is no VHDCI (like your 6250 has) or SCSI adapter necessary.
Christian
(4,171 Views)
