continuity tester
We used to call it a binary chop because you first test one half against the other half. Keep dividing in halves and comparing one half against the next. Think in exponents of 2. Two to the second is 4 so 4 pins requires 2+1 patterns. Two to the third is 8 so 8 pins requires 3+1 patterns. Two to the fourth is 32 so 32 pins requires 4+1.
Message 11 of 13
(1,614 Views)
Do you have any sample code for this tester?
Message 12 of 13
(960 Views)
Do you have a recommendation for a device that handles 91 total digital IO pins?
Message 13 of 13
(910 Views)
