continuos sampling gives attenuated values
On continuous sampling, I am trying to read 2 voltage signals SIMULTANEOUSLY.I am reading with PCI6221 card. with 10000-scan rate and 2500 samples /channel. this runs in a while
loop but the samples I get are attenuated in amplitude.
for eg if I am supposed to get 8V I get only 6V for these settings
if  i reduce the sampling rate and samples/ch  then i get pretty accurate reading
(3,212 Views)
Hello Akshay,
Thank you for your post. What kind of signal are you trying to read? s it floating or grounded? How do you measure; single ended, differential or pseudo differential?
Martijn
NI NL
Martijn S
NI Netherlands
(3,196 Views)
