continuous analog output
I am trying to use a pxi-6713 card to provide a 66.667kHz 5 volt continuous waveform.  The waveform though is not continuously running.  I am using DAQmx sample code to generate this signal in labview 8.2.
(3,225 Views)
I was looking at an example called Cont Gen Voltage Wfm-Int Clk that was in the LabVIEW shipping examples. How are you determining that the waveform is not continuously running? Do you have an analog input module that you can test with to see if your signal is continuously being generated? You may only be seeing a certain section of the DAQmx buffer when you look at it on the waveform.
Jake H | Product Manager
(3,203 Views)
I was using an oscilloscope, but I have since figured out what I was doing wrong.  By implementing the Labview example code, I am now able to get a continuous square wave.
(3,195 Views)
