control pump with daq
Hi everdy I have problem about communicate pump with Daq and labview2009. I want to know how to control pump with analog
voltage signal and how to calibrate pump that how many round per minute per voltage.
(3,973 Views)
Hi Harahara,
        We're definitely going to need a little more information about what hardware you're using and your general test setup.  Additionally, what problems are you seeing? If you're looking for some general information, I would recommend searching the Tutorials and Knowledge Base.  Please let us know if there are any specific questions we can help answer!
(3,956 Views)
I want to control the pressure reducing valve, flow control valve and hydraulic pump.
What can be the interface to to interact the PXI with the pump?
Is there any example VI for controlling valves or pump?
(3,691 Views)
(3,689 Views)
