03-31-2008 05:01 AM
04-04-2008 04:38 AM
Hi Paul,
in LabVIEW 8.5 there are plenty of examples you can take a look at.
That's the best way to learn and start practicing with this powerful software.
To search trough out the many examples you need to click on the "help" tab from LabVIEW Block Daigram or Front Panel.
Select from the menu "Find Examples" and you will be pointed to the Example Finder.
Look in the "Hardware Input and Output -> DAQmx -> Analog Measurements -> Temperature" folder; you can look at "Cont Acq Thermocouple Samples-Int Clk. vi".
At the same way for the fan control you can go in the folder "Hardware Input and Output -> DAQmx -> Analog Generation -> Voltage" and you can practice with a lot of VIs.
Andrea N.
04-04-2008 04:42 AM
