controlling flow from a paralstictic pump
I need to know how to control the flow from a paralstictic pumb with labview.
Ramon Garza
Baker Oil Tools
713-966-3222
(3,045 Views)
It's depend if your pump has a flow control system...
Every peristaltic pump i used have a on/off control only. I controlled the start/stop activation from a SCXI power realy module...
If your pump has flow control system, it is probably a PWM(Pulse width modulation) signal. You can generate that kind of signal using a DAQ board with counter output...
Hope this help.
Guillaume
(3,039 Views)
Hi Ramon,
What kind of control signal does your peristaltic pump require?  Is it expecting a voltage signal or does it use a communications protocol such as serial to receive commands for a controller at the pump itself?  There are a number of devices that can be controlled within LabVIEW that could be used to generate voltage signals for your pump.  If it uses a communications protocol like serial, there are also functions within LabVIEW that allow you to communicate in this manner.
Andrew W
(3,020 Views)
