convert j thermocouple to k
Hi all,
I wrote a Labview program to take temperature measurements using a NI921 plugged into a cDAQ9171. It all worked ok and I did a load of testing. When I came to review the data, I realized I'd incorrectly set some of the channels to j type thermocouples, when I'm actually using k type. Is there a way to convert the temperature data I've captured to valid readings? I'm guessing this will require knowing how the system converted the mV input from the thermocouple to degC for j types, reversing this process mathematically to re-gain the raw mV readings, then knowing how the system converts mV to degC for k types, and applying this.
Can anyone help?
Thanks!
Andy.
(4,883 Views)
Hi Andy,
Are you referring to NI-9213 or 9211?
Whichever way it is, you can refer to this link:
http://forums.ni.com/t5/LabVIEW/Can-I-convert-j-type-thermocouple-data-to-k-type/td-p/1597286
Hope this helps.
-Ee Lim-
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
(4,861 Views)
Thanks! I did try searching for the answer before posting, but my search-fu must have been weak.
(4,825 Views)
