creat acquisition system daq 6008 plz help iam in egypt
 hi all lab view  users
 i hag a big problem wish any one help
i buy a 6008 DAQ card  from here in egypt
and i instal it in my computer with a lab view version 7.1 cause lab view 8.5 canot see it
but in  7.1 version when i click  to add  Daq  input devise the labview load the DAq assistant to select the channel i select it and define the input as voltad due to acceleration
press ok
 but no nodes apear in  block diagram to wiring it  with the analysis of charts
plz look at photo and repla to me
(3,314 Views)
Hi alextroy,
What operating system are you working with? I will assume you have a Windows OS for now. When you connect the USB-6008 device to your computer does Windows recognize the device? You can tell if it is present in Device Manager. You should also be able to see and test your device by finding it under 'NI-DAQmx Devices' when you open up Measurement and Automation Explorer.
How were you able to create the good picture? Does your DAQ Assistant work as expected when you select a different type of measurement? Did you reinstall your drivers when LabVIEW 8.5 was installed on the computer? In Measurement and Automation Explorer you can expand the 'Software' section and find what NI software is installed. Which version of the NI-DAQmx driver do you have installed?
Steve B
(3,278 Views)
 thank you for  offer help
i am to day go to the  faculty
Smiley Sad
i use the daq and it work i gust reset the setup data and the sensor and it show the nodes to wiring the out put data
 put
when i put the spectral ison from analysis list to show the data on spectram  presentation  type ok
 but  LAbview start searching for a file dosnot exist named " tone and noise.Vi  "
and after that he tell me that no option can be show
i put the print screen with attachment
so what that means is my lab view is not complete
and why not ?
it should be complete i bye the DAQ original by more than  $ 250 dollar so all my software must be full
(3,274 Views)
Your attachment did not make it. If you click the Preview button, the attachment gets lost.
The VI you mention is not available with the Base version of LabVIEW. The price of the DAQ board has nothing to do with the price of the different versions of LabVIEW. If you select Help>About LabVIEW, it will show the version you have.
(3,269 Views)
this is my problem  picture in attachment
(3,252 Views)
You already said it was missing. You did not have to post a picture to prove that it could not be found. Did you do what I said? Look to see what LabVIEW system (base, full, professional), you are running? I'm not even sure what version of LabVIEW you are using since you mentioned both 7.1 and 8.5. You also said that 8.5 could not recognize the 6008. If you still have that problem, then you may have a bad installation of 8.5 or DAQmx.
(3,247 Views)
