cross reference of variable like DAQmx_Val_FromCustomScale
in NI-DaQmx C reference help tutorial, variables used throughout the tutorial such as "DAQmx_Val_FromCustomScale"  shall be sustituted with corresponding numbers such as 1007. Where can I find the cross reference table for all these variables??
(3,220 Views)
Hi MoShaz-
The definitions of the DAQmx_Val_... attribute values can be found in C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\NIDAQmx.h.  Depending on your version of NI-DAQmx, they should begin around line 850 or so.
Hopefully this helps-
Tom W
(3,212 Views)
