current measure 6008
hello all
i have a pressure transducer to aquire pressure to a USB6008.
The range of the transducer is 4-20mA linear but it floats alot.
Is there anyway to solve this?
Tim
(4,056 Views)
How is is the sensor hooked up to the 6008?
(There are better devices to measure a current loop (4-20mA)  )
Greetings from Germany
Henrik
LV since v3.1
(4,038 Views)
Hello timoteo,
To measure current the way to do it is to use the shunt resistor as explained here :
Measuring Current Using the Analog Input of a DAQ Board
And you can see this discussion
Steve M.
(4,031 Views)
Hello all,
Yes i know there are much better devices but they cost much more as well...
I use a shunt resistor of 240 Ohm sorry i didnt mencion it before, my problem is the stability of the signal!
I have tried to connect the transducer (Huba Control 691) to a eurotherm with a shunt resistor of 2,49Ohm to a analog input and work very stable that is my confusion. Does it have some kind of filter?
Do i need to use a special filter? i have tried as well change the samples rate and number of samples.
Normal configuration is single channel RSE 1 Sample on demand.
Tim
(4,021 Views)
Can you clarify your behaviour or can you attach a screenshot of what you see ? Please take a look at this useful link :
Has anyone measured strain with a USB DAQ device such as the 6008?
Also, there is a developer zone article that you might find it helpful: Field Wiring and Noise Considerations for Analog Signals.
Steve M.
(4,009 Views)
