daq 6.9.3 to labview 7.1
Hi Jeff:
Thanks for your reply. I tried today several time and still got
nothing. I did not find the daq files you mentioned in labview 7.1 file
after the installation followed the instruction. how ever i found the
nidaq.exe in the nidaq file of  daq 6.9.3 driver file. if i run it and
install the lv6.1 support in the directory of c:\Nationinstrument\labview 6.1 , I found the daq files which i guess
should be installed in the labview 7.1. could you tell me how to do it
manually?
thanks
sanguo
support@ni.com wrote:
>Note:  Your reference number is included in the subject field of this
>message.  It is very important not to remove or modify this reference
>number, or your message may be returned to you.
>Sanguo,
>Thank you for contacting National Instruments Support.  I am surprised
that
>you are having difficulties with this KB because I have performed the
>operation several times without any problems.  It is important to note
that
>DAQ 6.9.3 cannot coexist with DAQmx or any later versions of Traditional
>DAQ.  Do you have DAQmx or Traditional DAQ 7.x installed on this
computer?
>If so they much be completely uninstalled before you attempt the steps
in
>this KB.
>Can you also check the following directories in your computer?
>C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib
>This should have a directory called "daq"
>C:\Program Files\National Instruments\LabVIEW 7.1\examples
>This should also have a directory called "daq"
>C:\Program Files\National Instruments\LabVIEW 7.1\help
>This directory should have some daq files
>C:\Program Files\National Instruments\LabVIEW 7.1\menus\default
This
>directory should have a "daq" folder as well.
>See if any of these files are in the correct place.  Maybe we can fix
the
>problem manually.
>Sincerely
>Jeff Tipps
>Applications Engineer
http://www.ni.com/support
>Problem Description :
>Dear NI engineers:
>I install the labview 7.1 to my PC, however the daq card i am using is
not
>supported by the new daq 7.x driver. I have to install the daq 6.9.3.
>I strictly follow the instruction of the "Using Older Versions of NI-DAQ
>(6.9.3) with LabVIEW 7.x or 8.x" in the knowledgebase: 1,download the
daq
>6.9.3(the install language of this driver is german.)2. download the
>LV61Eng.exe. I extract both of them in the same file. then i install it
by
>click the setup.exe. In the feature tree, i selected the labview 6.1
>support and change to "Install this feature and sub_features to the
local
>hardware". I also change the directory on the bottom to C:\Program
>Files\National Instruments\LabVIEW 7.1\ .  After the installation and
>restart of the pc. The daq file is not added to the vi.lib and the DAQ
>pallette is empty. I tried decades of times, however it still does not
>work. Please help me out. i am almost desperate. Thanks!!!!!!!
>regards
>sanguo
>NI Software :
>LabVIEW  version 7.1
>NI Hardware :
>Multifunction DAQ device DAQCARD-AI-16E-4
>Driver Version :
>daq 6.9.3
>OS :
>Windows XP
>Customer Information :
>li
>sanguo
>stevens inst of tech
>US
>sli@stevens.edu
>Ph:
>201
>-2165662
Message 1 of 1
(3,147 Views)
