daq 6218 - what is the smallest change in the signal that it can detect?
I want to know what is the minimum analog voltage detectable by DAQ6218 which is 16 bit?
I found the following document
https://www.ni.com/en/shop/data-acquisition/how-to-choose-the-right-daq-hardware-for-your-measuremen...
Here is was written "Typical DAQ devices have voltage ranges of +/-5 V or +/-10 V. The voltage levels that can be represented are distributed evenly across a selected range to take advantage of the full resolution. For example, a DAQ device with a +/-10 V range and 12 bits of resolution (212 or 4,096 evenly distributed levels) can detect a 5 mV change, where a device with 16 bits of resolution (216 or 65,536 evenly distributed levels) can detect a 300 µV change."
But if we check the specification of the DAQ6218 the sensitivity for the input range +/-10V is given as 91.6µV. (http://www.ni.com/datasheet/pdf/en/ds-9)(page no 7/18).
Can anyone please clarify about the minimum voltage detectable by DAQ6218?
thanks and regards
sanjeet
(3,528 Views)
That sensitivity number is perhaps a bit conterintuitive. It is explained in this whitepaper.
Also, note that the accuracy numbers in the table assume 100 readings.
(3,252 Views)
