daq 6281 used as a current source
Does anyone know if DAQ 6281-M can be used as a current source and how?
Ruq
(2,886 Views)
Ruq,
The specifications make it clear that the 6281 AO is a voltage source with current limited to 5 mA.
If your maximum current requirement is less than that you might be able to use a large value resistor in series with the voltage output to simulate a current source.
Lynn
(2,881 Views)
