daq card with MAtlab
Hi friends,
I am a PhD student at a university and working on a system for my thesis.
I need to send current to my system (4 20mA)and I get voltage data (1-2V)from the system.I searhed your products but could not find the one I need.
Can you please help me which one of your product will be better for me. I called the distributor in our country but the man was not good enough to inform and help me. And I visited the web site of Mathworks to check if the one (pci 6239) is compatible but 623 is not in the list.
So I need any DAQ card (pci or usb) which send current to the system and reads voltage from the system which is compatible with Matlab.
Can you please help me about that..
Thanks..
(3,158 Views)
Hi turker,
To do current output, I would suggest using one of our M Series data acquistion cards along with the SC-2345 and the SCC-CO20 module.  You could then use one of the Voltage Analog Input Modules for your analog input.
I hope this helps!
Erik J
(3,139 Views)
