daq ni 6009
any driver circuit required to control 12v DC fan by DAQ card ?
(4,977 Views)
Yes.
(4,964 Views)
thank you sir!!!
please suggest suitable driver for driving 12v dc fan.
how many 12v dc motor can be control in NI6009 DAQ?
(4,918 Views)
that is not good idea use 6009 for this one but your answer is
2 motor with analog out put
and 8 motor with digital output
and you just need to use amplifier to convert 5 dc volt to 12 dc also
depand on your fan current use you have to use some amplifier for 20m am to that current
this is all I know
but try use some isolate method before it to make your daq in safe mode
(4,878 Views)
thank you sir .
please tell me the formula for MQ-135, MQ-7 gas sensor conversion of voltage into co, ppm?
(4,873 Views)
just read their manual
(4,820 Views)
