daq system is running slow
Hi reggie,
I have been running your code and without highlighted execution I get the 4.3 seconds AI reading, using the settings you sent in the previous document.
Are you changing anything else?
Also just as a reminder, if this is happening when you have the highlight execution tool ON, then it is expected for it to slow down the measurement, since it  greatly reduces the speed at which the VI runs.
Carolina
Message 11 of 20
(3,097 Views)
Even when I have it off highlighted execution it takes about a minute to get through AI reading to where I do not get any data. I have tried restarting the computer and unplugging the DAQ system but that does not work either.
Message 12 of 20
(3,093 Views)
Hi reggie2016,
Have you tried to run an AI task in NI-MAX and check if you are getting data correctly?
This Knowledge Base article shows how to create a task
How Do I Create a Task In MAX with Multiple Analog Measurement Types?
http://digital.ni.com/public.nsf/allkb/F28C6BD62B0ED68F86257A6B00733E0E
Carolina
Message 13 of 20
(3,069 Views)
Yes I have tried it but it gets stuck at one spot every time. Should I uninstall labview and reinstall it?
Message 14 of 20
(3,032 Views)
Hi reggie2016,
What do you mean that it gets stuck at one spot every time? Are you doing that in NI-MAX?
You could attach pictures of what you are looking at.
I would not go right away to reinstall LabVIEW. If it is an issue with installation, I would start first trying to repair the driver (DAQmx).
But I am not sure what is it that you are doing, so I would not jump right away to that.
Carolina
Message 15 of 20
(3,020 Views)
Where the green arrow is in the picture, it stays there for a minute reading something like there is a wait timer on or something. I do not have a wait timer on so it should run through the program without any delays. would uninstalling the drivers and reinstalling them be a good idea?
Message 16 of 20
(3,014 Views)
I dont know if I can use task because I am trying to read alot of samples in a short amount of time.
Message 17 of 20
(3,011 Views)
Hi reggie2016,
I can see in the picture you attached that you are running it in Highlighted execution. Does it also stays there if you turn it off?
And in MAX you can configure the tasks to read as you have it in LabVIEW.
Carolina
Message 18 of 20
(2,983 Views)
I finally got it to work. It was as simple as creating a new TDMS file to save the data to. Thank you for all your help!
Message 19 of 20
(2,965 Views)
I am glad to hear that you got it working!
Carolina
Message 20 of 20
(2,948 Views)
