daq+visa+priority
Hello, I'm programming a .vi for adquiring data from 2 devices. I adquire data via serial port  (visa) each 0.1 seconds, and  I adquire data from a DAQ  each 0.5 ms. I notice that i'm loosing data received by serial port, and i don't want this. What can I do to solve this?
 Luz
(3,214 Views)
Are they not in seperate while loops??
If not, put them in seperate while loops
(3,211 Views)
Hi all,
Devchander is right, u should use two while loops with different timing for each one.
I will add something, do not connect any wire from the output of one loop to as input to the other one because that will give u errors. If u want to pass data from one loop to the other one (for example sharing the stop button) use local variables,
Jaime Cabrera
NI Applications Engineering Spain
Jaime Cabrera
(3,192 Views)
