daqmx C interface - how can i know (via function or property) if a device is disconnected
So i got a couple of devices (of the same type 6008) connected and then disconnected. Each of the device gets a unique dev/ number.
Then i iterate through the list  via DAQmxGetDevProductType and it finds all the devices.
Is there a special function or property that i can run to know if the device is actually connected at the moment with the PC?
thanks!
(2,870 Views)
