dasylab- Load/displacement Help please
I am running a test program which involves applying a load of 40t to a component and measuring displacement with dasylab 12. a former employee has created a worksheet for a similar test which i was hoping to use for my test. However, i have never used this software before and while running a dry run of the test I noticed that dasylab wont register a load after 35t. Could the worksheet have a cap on it to only register upto 35t? and if so where/how would i edit it to allow 40t?
Any help would be greatly appreciated.
Kevin
(4,216 Views)
Kevin,
Could you post your worksheet?  Maybe is something easy that we can look into it.
Also, I would need to know which DAQ board you are using.
It could also be that the amplifier is set to get maximum output at 35t or that the DAQ board has a range selected to max out at 35t.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(4,187 Views)
