data aquisition: temperature, pressure and humidity
I want to connect with labview a data aquisition board that measures temperature, pressure and humidity and it's connected on a parallel port.
(3,143 Views)
Great! What's the question?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,136 Views)
Your question should have been posted to a different board since this one is for NI DAQ hardware.
There is an example that will read or write the parallel port. Look for Parallel Port Read and Write Loop.vi. You can also use the VISA functions.
p.s. You need to actually ask a question.
(3,135 Views)
