delete device in max
hi,
i have installed ni-daqmx 9.8 core, max 5.5.1 and system config runtime 5.5.1.
i can install a simulated device via .nce file alone and using labWindows in c++, but i cannot delete them in max. there simply is no option when i right-click on the device in max.
i also cannot install another simulated device in max due to a missing option anywhere.
do i have to install another component?
thanx.
(4,448 Views)
You need to install NI-DAQmx Configuration support from the Full DAQmx distribution.
(4,438 Views)
