delphi support pci1200 card
for a particular project I'm working on, I'm using a National
Instruments LAB-PC-1200AI card. The thing is, I have to be using Delphi as a
programing language rather than LabView which makes things rather tricky.
in the support examples given along , there is an delphi application that turns on the leds and turns them off , but this only runs for 5 minutes , i need to make it run for a longer time , after 5 minutes the message flashes that contact ni about the code . is there a way i can access the i/0 lines of the daq using delphi , if so is there some documentation about the libraries and procedures and stuff , and where could i get the pdf documents for that .i wont be using labview and only delphi so need to work with it only
(4,534 Views)
this is the unit for E-series working with NIdaq7.01 and maybe 6.9.x
NI-DAQ Header file for Borland Delphi (32-bit)
Copyright (C) National Instruments 2000.
ge�ndert 11.03
unit NIDAQ;
interface
uses Windows;
type
i8 = ShortInt;
u8 = Byte;
pi8 = PChar;
i16 = SmallInt;
u16 = Word;
pi16 = ^i16;
pu16 = ^u16;
i32 = LongInt;
u32 = Cardinal;
pi32 = ^i32;
pu32 = ^u32;
f32 = Single;
f64 = Double;
pf64 = ^f64;
nidaqStatus = i16;
const
nidaqdll = 'nidaq32.dll';
CONST ND_AC = 11025; { NIDAQCNS.PAS}
ND_BASE_ADDRESS = 12100;
(* ND_ABOVE_HIGH_LEVEL = 11020;
ND_ACK_REQ_EXCHANGE_GR1 = 11030;
ND_ACK_REQ_EXCHANGE_GR2 = 11035;
ND_ACTIVE = 11037;
ND_ADC_RESOLUTION = 11040;
ND_AI_CALDAC_COUNT = 11050;
ND_AI_CHANNEL_COUNT = 11060;
ND_AI_COUPLING = 11055;
ND_AI_FIFO_INTERRUPTS = 11600;
ND_ANALOG_FILTER = 11065;
ND_AO48XDC_SET_POWERUP_STATE = 42100;
ND_AO_CALDAC_COUNT = 11070;
ND_AO_CHANNEL_COUNT = 11080;
ND_AO_EXT_REF_CAPABLE = 11090;
ND_AO_UNIPOLAR_CAPABLE = 11095;
ND_ARM = 11100;
ND_ARMED = 11200;
ND_ATC_OUT = 11250;
ND_ATTENUATION = 11260;
ND_AUTOINCREMENT_COUNT = 11300;
ND_AUTOMATIC = 11400;
ND_AVAILABLE_POINTS = 11500;
ND_BELOW_LOW_LEVEL = 12130;
ND_BOARD_CLOCK = 12170;
ND_BUFFERED_EVENT_CNT = 12200;
ND_BUFFERED_PERIOD_MSR = 12300;
ND_BUFFERED_PULSE_WIDTH_MSR = 12400;
ND_BUFFERED_SEMI_PERIOD_MSR = 12500;
ND_BURST = 12600;
ND_BURST_INTERVAL = 12700;
ND_CAL_CONST_AUTO_LOAD = 13050;
ND_CALIBRATION_ENABLE = 13055;
ND_CALIBRATION_FRAME_SIZE = 13060;
ND_CALIBRATION_FRAME_PTR = 13065;
ND_CJ_TEMP = ($8000);
ND_CALGND = ($8001);
ND_CLEAN_UP = 13100;
ND_CLOCK_REVERSE_MODE_GR1 = 13120;
ND_CLOCK_REVERSE_MODE_GR2 = 13130;
ND_CONFIG_MEMORY_SIZE = 13150;
ND_CONTINUOUS = 13160;
ND_COUNT = 13200;
ND_COUNTER_0 = 13300;
ND_COUNTER_1 = 13400;
ND_COUNTER_2 = 13310;
ND_COUNTER_3 = 13320;
ND_COUNTER_4 = 13330;
ND_COUNTER_5 = 13340;
ND_COUNTER_6 = 13350;
ND_COUNTER_7 = 13360;
ND_COUNTER_1_SOURCE = 13430;
ND_COUNT_AVAILABLE = 13450;
ND_COUNT_DOWN = 13465;
ND_COUNT_UP = 13485;
ND_COUNT_1 = 13500;
ND_COUNT_2 = 13600;
ND_COUNT_3 = 13700;
ND_COUNT_4 = 13800;
ND_CURRENT_OUTPUT = 40200;
ND_DAC_RESOLUTION = 13950;
ND_DATA_TRANSFER_CONDITION = 13960;
ND_DATA_XFER_MODE_AI = 14000;
ND_DATA_XFER_MODE_AO_GR1 = 14100;
ND_DATA_XFER_MODE_AO_GR2 = 14200;
ND_DATA_XFER_MODE_DIO_GR1 = 14300;
ND_DATA_XFER_MODE_DIO_GR2 = 14400;
ND_DATA_XFER_MODE_DIO_GR3 = 14500;
ND_DATA_XFER_MODE_DIO_GR4 = 14600;
ND_DATA_XFER_MODE_DIO_GR5 = 14700;
ND_DATA_XFER_MODE_DIO_GR6 = 14800;
ND_DATA_XFER_MODE_DIO_GR7 = 14900;
ND_DATA_XFER_MODE_DIO_GR8 = 15000;
ND_DATA_XFER_MODE_GPCTR0 = 15100;
ND_DATA_XFER_MODE_GPCTR1 = 15200;
ND_DATA_XFER_MODE_GPCTR2 = 15110;
ND_DATA_XFER_MODE_GPCTR3 = 15120;
ND_DATA_XFER_MODE_GPCTR4 = 15130;
ND_DATA_XFER_MODE_GPCTR5 = 15140;
ND_DATA_XFER_MODE_GPCTR6 = 15150;
ND_DATA_XFER_MODE_GPCTR7 = 15160;
ND_DATA_XFER_MODE_GPCTR8 = 15165;
ND_DATA_XFER_MODE_GPCTR9 = 15170;
ND_DATA_XFER_MODE_GPCTR10 = 15175;
ND_DATA_XFER_MODE_GPCTR11 = 15180;
ND_DC = 15250;
ND_DDS_BUFFER_SIZE = 15255;
ND_DEVICE_NAME = 15260;
ND_DEVICE_POWER = 15270;
ND_DEVICE_SERIAL_NUMBER = 15280;
ND_DEVICE_STATE_DURING_SUSPEND_MODE = 15290;
ND_DEVICE_TYPE_CODE = 15300;
ND_DIGITAL_FILTER = 15350;
ND_DIGITAL_RESTART = 15375;
ND_DIO128_GET_PORT_THRESHOLD = 41200;
ND_DIO128_SELECT_INPUT_PORT = 41100;
ND_DIO128_SET_PORT_THRESHOLD = 41300;
ND_DISABLED = 15400;
ND_DISARM = 15450;
ND_DIVIDE_DOWN_SAMPLING_SUPPORTED = 15475;
ND_DMA_A_LEVEL = 15500;
ND_DMA_B_LEVEL = 15600;
ND_DMA_C_LEVEL = 15700;
ND_DONE = 15800;
ND_DONT_CARE = 15900;
ND_DONT_KNOW = 15950;
ND_EDGE_SENSITIVE = 16000;
ND_ENABLED = 16050;
ND_END = 16055;
ND_EXTERNAL = 16060;
ND_EXTERNAL_CALIBRATE = 16100;
ND_FACTORY_CALIBRATION_EQUIP = 16210;
ND_FACTORY_EEPROM_AREA = 16220;
ND_FIFO_EMPTY = 16230;
ND_FIFO_HALF_FULL_OR_LESS = 16240;
ND_FIFO_HALF_FULL_OR_LESS_UNTIL_FULL = 16245;
ND_FIFO_NOT_FULL = 16250;
ND_FIFO_TRANSFER_COUNT = 16260;
ND_FILTER_CORRECTION_FREQ = 16300;
ND_FOREGROUND = 16350;
ND_FREQ_OUT = 16400;
ND_FSK = 16500;
ND_EDGE_BASED_FSK = 16500;
ND_GATE = 17100;
ND_GATE_POLARITY = 17200;
ND_GPCTR0_GATE = 17300;
ND_GPCTR0_OUTPUT = 17400;
ND_GPCTR0_SOURCE = 17500;
ND_GPCTR1_GATE = 17600;
ND_GPCTR1_OUTPUT = 17700;
ND_GPCTR1_SOURCE = 17800;
ND_GPCTR2_GATE = 17320;
ND_GPCTR2_OUTPUT = 17420;
ND_GPCTR2_SOURCE = 17520;
ND_GPCTR3_GATE = 17330;
ND_GPCTR3_OUTPUT = 17430;
ND_GPCTR3_SOURCE = 17530;
ND_GPCTR4_GATE = 17340;
ND_GPCTR4_OUTPUT = 17440;
ND_GPCTR4_SOURCE = 17540;
ND_GPCTR5_GATE = 17350;
ND_GPCTR5_OUTPUT = 17450;
ND_GPCTR5_SOURCE = 17550;
ND_GPCTR6_GATE = 17360;
ND_GPCTR6_OUTPUT = 17460;
ND_GPCTR6_SOURCE = 17660;
ND_GPCTR7_GATE = 17370;
ND_GPCTR7_OUTPUT = 17470;
ND_GPCTR7_SOURCE = 17570;
ND_GROUND_DAC_REFERENCE = 17900;
ND_HARDWARE = 18000;
ND_HI_RES_SAMPLING = 18020;
ND_HIGH = 18050;
ND_HIGH_HYSTERESIS = 18080;
ND_HIGH_TO_LOW = 18100;
ND_HW_ANALOG_TRIGGER = 18900;
ND_IMPEDANCE = 19000;
ND_INACTIVE = 19010;
ND_INITIAL_COUNT = 19100;
ND_INIT_PLUGPLAY_DEVICES = 19110;
ND_INSIDE_REGION = 19150;
ND_INTERNAL = 19160;
ND_INTERNAL_100_KHZ = 19200;
ND_INTERNAL_10_MHZ = 19300;
ND_INTERNAL_1250_KHZ = 19320;
ND_INTERNAL_20_MHZ = 19400;
ND_INTERNAL_25_MHZ = 19410;
ND_INTERNAL_2500_KHZ = 19420;
ND_INTERNAL_5_MHZ = 19450;
ND_INTERNAL_7160_KHZ = 19460;
ND_INTERNAL_TIMER = 19500;
ND_INTERRUPTS = 19600;
ND_INTERRUPT_A_LEVEL = 19700;
ND_INTERRUPT_B_LEVEL = 19800;
ND_INTERRUPT_TRIGGER_MODE = 19850;
ND_IN_CHANNEL_CLOCK_TIMEBASE = 19900;
ND_IN_CHANNEL_CLOCK_TB_POL = 20000;
ND_IN_CONVERT = 20100;
ND_IN_CONVERT_POL = 20200;
ND_IN_DATA_FIFO_SIZE = 20250;
ND_IN_EXTERNAL_GATE = 20300;
ND_IN_EXTERNAL_GATE_POL = 20400;
ND_IN_SCAN_CLOCK_TIMEBASE = 20500;
ND_IN_SCAN_CLOCK_TB_POL = 20600;
ND_IN_SCAN_IN_PROG = 20650;
ND_IN_SCAN_START = 20700;
ND_IN_SCAN_START_POL = 20800;
ND_IN_START_TRIGGER = 20900;
ND_IN_START_TRIGGER_POL = 21000;
ND_IN_STOP_TRIGGER = 21100;
ND_IN_STOP_TRIGGER_POL = 21200;
ND_INT_AI_GND = 21210;
ND_INT_AO_CH_0 = 21230;
ND_INT_AO_CH_0_VS_REF_5V = 21235;
ND_INT_AO_CH_1 = 21240;
ND_INT_AO_CH_1_VS_AO_CH_0 = 21245;
ND_INT_AO_CH_1_VS_REF_5V = 21250;
ND_INT_AO_CH_2 = 21220;
ND_INT_AO_CH_3 = 21221;
ND_INT_AO_CH_4 = 21222;
ND_INT_AO_CH_5 = 21223;
ND_INT_AO_CH_6 = 21224;
ND_INT_AO_CH_7 = 21225;
ND_INT_AO_GND = 21260;
ND_INT_AO_GND_VS_AI_GND = 21265;
ND_INT_CM_REF_5V = 21270;
ND_INT_DEV_TEMP = 21280;
ND_INT_REF_5V = 21290;
ND_INT_REF_EXTERN = 21296;
ND_INT_CAL_BUS = 21295;
ND_INT_MUX_BUS = 21305;
ND_INT_AI_GND_AMP_0 = 21211;
ND_INT_AI_GND_AMP_1 = 21212;
ND_INT_AI_GND_AMP_2 = 21213;
ND_INT_AI_GND_AMP_3 = 21214;
ND_INT_AO_CH_0_AMP_0 = 21231;
ND_INT_AO_CH_0_AMP_1 = 21232;
ND_INT_AO_CH_0_AMP_2 = 21233;
ND_INT_AO_CH_0_AMP_3 = 21234;
ND_INT_AO_CH_1_AMP_0 = 21241;
ND_INT_AO_CH_1_AMP_1 = 21242;
ND_INT_AO_CH_1_AMP_2 = 21243;
ND_INT_AO_CH_1_AMP_3 = 21244;
ND_INT_AO_CH_0_VS_REF_AMP_0 = 21236;
ND_INT_AO_CH_0_VS_REF_AMP_1 = 21237;
ND_INT_AO_CH_0_VS_REF_AMP_2 = 21238;
ND_INT_AO_CH_0_VS_REF_AMP_3 = 21239;
ND_INT_AO_CH_1_VS_REF_AMP_0 = 21251;
ND_INT_AO_CH_1_VS_REF_AMP_1 = 21252;
ND_INT_AO_CH_1_VS_REF_AMP_2 = 21253;
ND_INT_AO_CH_1_VS_REF_AMP_3 = 21254;
ND_INT_AO_GND_VS_AI_GND_AMP_0 = 21266;
ND_INT_AO_GND_VS_AI_GND_AMP_1 = 21267;
ND_INT_AO_GND_VS_AI_GND_AMP_2 = 21268;
ND_INT_AO_GND_VS_AI_GND_AMP_3 = 21269;
ND_INT_CM_REF_AMP_0 = 21271;
ND_INT_CM_REF_AMP_1 = 21272;
ND_INT_CM_REF_AMP_2 = 21273;
ND_INT_CM_REF_AMP_3 = 21274;
ND_INT_REF_AMP_0 = 21291;
ND_INT_REF_AMP_1 = 21292;
ND_INT_REF_AMP_2 = 21293;
ND_INT_REF_AMP_3 = 21294;
ND_INTERRUPT_EVERY_SAMPLE = 11700;
ND_INTERRUPT_HALF_FIFO = 11800;
ND_IO_CONNECTOR = 21300;
ND_LEVEL_SENSITIVE = 24000;
ND_LINK_COMPLETE_INTERRUPTS = 24010;
ND_LOW = 24050;
ND_LOW_HYSTERESIS = 24080;
ND_LOW_TO_HIGH = 24100;
ND_LPT_DEVICE_MODE = 24200;
ND_MARKER = 24500;
ND_MARKER_QUANTUM = 24550;
ND_MAX_ARB_SEQUENCE_LENGTH = 24600;
ND_MAX_FUNC_SEQUENCE_LENGTH = 24610;
ND_MAX_LOOP_COUNT = 24620;
ND_MAX_NUM_WAVEFORMS = 24630;
ND_MAX_SAMPLE_RATE = 24640;
ND_MAX_WFM_SIZE = 24650;
ND_MEMORY_TRANSFER_WIDTH = 24700;
ND_MIN_SAMPLE_RATE = 24800;
ND_MIN_WFM_SIZE = 24810;
ND_NEGATIVE = 26100;
ND_NEW = 26190;
ND_NI_DAQ_SW_AREA = 26195;
ND_NO = 26200;
ND_NO_STRAIN_GAUGE = 26225;
ND_NO_TRACK_AND_HOLD = 26250;
ND_NONE = 26300;
ND_NOT_APPLICABLE = 26400;
ND_NUMBER_DIG_PORTS = 26500;
ND_OFF = 27010;
ND_OFFSET = 27020;
ND_ON = 27050;
ND_OTHER = 27060;
ND_OTHER_GPCTR_OUTPUT = 27300;
ND_OTHER_GPCTR_TC = 27400;
ND_OUT_DATA_FIFO_SIZE = 27070;
ND_OUT_EXTERNAL_GATE = 27080;
ND_OUT_EXTERNAL_GATE_POL = 27082;
ND_OUT_START_TRIGGER = 27100;
ND_OUT_START_TRIGGER_POL = 27102;
ND_OUT_UPDATE = 27200;
ND_OUT_UPDATE_POL = 27202;
ND_OUT_UPDATE_CLOCK_TIMEBASE = 27210;
ND_OUT_UPDATE_CLOCK_TB_POL = 27212;
ND_OUTPUT_ENABLE = 27220;
ND_OUTPUT_MODE = 27230;
ND_OUTPUT_POLARITY = 27240;
ND_OUTPUT_STATE = 27250;
ND_OUTPUT_TYPE = 40000;
ND_DIGITAL_PATTERN_GENERATION = 28030;
ND_PAUSE = 28040;
ND_PAUSE_ON_HIGH = 28045;
ND_PAUSE_ON_LOW = 28050;
ND_PFI_0 = 28100;
ND_PFI_1 = 28200;
ND_PFI_2 = 28300;
ND_PFI_3 = 28400;
ND_PFI_4 = 28500;
ND_PFI_5 = 28600;
ND_PFI_6 = 28700;
ND_PFI_7 = 28800;
ND_PFI_8 = 28900;
ND_PFI_9 = 29000;
ND_PFI_10 = 50280;
ND_PFI_11 = 50290;
ND_PFI_12 = 50300;
ND_PFI_13 = 50310;
ND_PFI_14 = 50320;
ND_PFI_15 = 50330;
ND_PFI_16 = 50340;
ND_PFI_17 = 50350;
ND_PFI_18 = 50360;
ND_PFI_19 = 50370;
ND_PFI_20 = 50380;
ND_PFI_21 = 50390;
ND_PFI_22 = 50400;
ND_PFI_23 = 50410;
ND_PFI_24 = 50420;
ND_PFI_25 = 50430;
ND_PFI_26 = 50440;
ND_PFI_27 = 50450;
ND_PFI_28 = 50460;
ND_PFI_29 = 50470;
ND_PFI_30 = 50480;
ND_PFI_31 = 50490;
ND_PFI_32 = 50500;
ND_PFI_33 = 50510;
ND_PFI_34 = 50520;
ND_PFI_35 = 50530;
ND_PFI_36 = 50540;
ND_PFI_37 = 50550;
ND_PFI_38 = 50560;
ND_PFI_39 = 50570;
ND_PLL_REF_FREQ = 29010;
ND_PLL_REF_SOURCE = 29020;
ND_PRE_ARM = 29050;
ND_POSITIVE = 29100;
ND_PREPARE = 29200;
ND_PROGRAM = 29300;
ND_PULSE = 29350;
ND_PULSE_SOURCE = 29500;
ND_PULSE_TRAIN_GNR = 29600;
ND_PXI_BACKPLANE_CLOCK = 29900;
ND_REGLITCH = 31000;
ND_RESERVED = 31100;
ND_RESET = 31200;
ND_RESUME = 31250;
ND_RETRIG_PULSE_GNR = 31300;
ND_REVISION = 31350;
ND_RTSI_0 = 31400;
ND_RTSI_1 = 31500;
ND_RTSI_2 = 31600;
ND_RTSI_3 = 31700;
ND_RTSI_4 = 31800;
ND_RTSI_5 = 31900;
ND_RTSI_6 = 32000;
ND_RTSI_CLOCK = 32100;
ND_SCANCLK = 32400;
ND_SCANCLK_LINE = 32420;
ND_SC_2040_MODE = 32500;
ND_SC_2043_MODE = 32600;
ND_SELF_CALIBRATE = 32700;
ND_SET_DEFAULT_LOAD_AREA = 32800;
ND_RESTORE_FACTORY_CALIBRATION = 32810;
ND_SET_POWERUP_STATE = 42100;
ND_SIMPLE_EVENT_CNT = 33100;
ND_SINGLE = 33150;
ND_SINGLE_PERIOD_MSR = 33200;
ND_SINGLE_PULSE_GNR = 33300;
ND_SINGLE_PULSE_WIDTH_MSR = 33400;
ND_SINGLE_TRIG_PULSE_GNR = 33500;
ND_SOURCE = 33700;
ND_SOURCE_POLARITY = 33800;
ND_STABLE_10_MHZ = 33810;
ND_STEPPED = 33825;
ND_STRAIN_GAUGE = 33850;
ND_STRAIN_GAUGE_EX0 = 33875;
ND_SUB_REVISION = 33900;
ND_SYNC_DUTY_CYCLE_HIGH = 33930;
ND_SYNC_OUT = 33970;
ND_TC_REACHED = 34100;
ND_THE_AI_CHANNEL = 34400;
ND_TOGGLE = 34700;
ND_TOGGLE_GATE = 34800;
ND_TRACK_AND_HOLD = 34850;
ND_TRIG_PULSE_WIDTH_MSR = 34900;
ND_TRIGGER_SOURCE = 34930;
ND_TRIGGER_MODE = 34970;
ND_UI2_TC = 35100;
ND_UP_DOWN = 35150;
ND_UP_TO_1_DMA_CHANNEL = 35200;
ND_UP_TO_2_DMA_CHANNELS = 35300;
ND_USE_CAL_CHAN = 36000;
ND_USE_AUX_CHAN = 36100;
ND_USER_EEPROM_AREA = 37000;
ND_USER_EEPROM_AREA_2 = 37010;
ND_USER_EEPROM_AREA_3 = 37020;
ND_USER_EEPROM_AREA_4 = 37030;
ND_USER_EEPROM_AREA_5 = 37040;
ND_DSA_RTSI_CLOCK_AD = 44000;
ND_DSA_RTSI_CLOCK_DA = 44010;
ND_DSA_OUTPUT_TRIGGER = 44020;
ND_DSA_INPUT_TRIGGER = 44030;
ND_DSA_SHARC_TRIGGER = 44040;
ND_DSA_ANALOG_TRIGGER = 44050;
ND_DSA_HOST_TRIGGER = 44060;
ND_DSA_EXTERNAL_DIGITAL_TRIGGER = 44070;
ND_VOLTAGE_OUTPUT = 40100;
ND_VOLTAGE_REFERENCE = 38000;
ND_VXI_SC = ($2000);
ND_PXI_SC = ($2010);
ND_VXIMIO_SET_ALLOCATE_MODE = 43100;
ND_VXIMIO_USE_ONBOARD_MEMORY_AI = 43500;
ND_VXIMIO_USE_ONBOARD_MEMORY_AO = 43600;
ND_VXIMIO_USE_ONBOARD_MEMORY_GPCTR = 43700;
ND_VXIMIO_USE_PC_MEMORY_AI = 43200;
ND_VXIMIO_USE_PC_MEMORY_AO = 43300;
ND_VXIMIO_USE_PC_MEMORY_GPCTR = 43400;
ND_WFM_QUANTUM = 45000;
ND_YES = 39100;
ND_3V_LEVEL = 43450;
ND_WRITE_MARK = 50000;
ND_READ_MARK = 50010;
ND_BUFFER_START = 50020;
ND_TRIGGER_POINT = 50025;
ND_BUFFER_MODE = 50030;
ND_DOUBLE = 50050;
ND_QUADRATURE_ENCODER_X1 = 50070;
ND_QUADRATURE_ENCODER_X2 = 50080;
ND_QUADRATURE_ENCODER_X4 = 50090;
ND_TWO_PULSE_COUNTING = 50100;
ND_LINE_FILTER = 50110;
ND_SYNCHRONIZATION = 50120;
ND_5_MICROSECONDS = 50130;
ND_1_MICROSECOND = 50140;
ND_500_NANOSECONDS = 50150;
ND_100_NANOSECONDS = 50160;
ND_1_MILLISECOND = 50170;
ND_10_MILLISECONDS = 50180;
ND_100_MILLISECONDS = 50190;
ND_OTHER_GPCTR_SOURCE = 50580;
ND_OTHER_GPCTR_GATE = 50590;
ND_AUX_LINE = 50600;
ND_AUX_LINE_POLARITY = 50610;
ND_TWO_SIGNAL_EDGE_SEPARATION_MSR = 50630;
ND_BUFFERED_TWO_SIGNAL_EDGE_SEPARATION_MSR = 50640;
ND_SWITCH_CYCLE = 50650;
ND_INTERNAL_MAX_TIMEBASE = 50660;
ND_PRESCALE_VALUE = 50670;
ND_MAX_PRESCALE = 50690;
ND_INTERNAL_LINE_0 = 50710;
ND_INTERNAL_LINE_1 = 50720;
ND_INTERNAL_LINE_2 = 50730;
ND_INTERNAL_LINE_3 = 50740;
ND_INTERNAL_LINE_4 = 50750;
ND_INTERNAL_LINE_5 = 50760;
ND_INTERNAL_LINE_6 = 50770;
ND_INTERNAL_LINE_7 = 50780;
ND_INTERNAL_LINE_8 = 50790;
ND_INTERNAL_LINE_9 = 50800;
ND_INTERNAL_LINE_10 = 50810;
ND_INTERNAL_LINE_11 = 50820;
ND_INTERNAL_LINE_12 = 50830;
ND_INTERNAL_LINE_13 = 50840;
ND_INTERNAL_LINE_14 = 50850;
ND_INTERNAL_LINE_15 = 50860;
ND_INTERNAL_LINE_16 = 50862;
ND_INTERNAL_LINE_17 = 50864;
ND_INTERNAL_LINE_18 = 50866;
ND_INTERNAL_LINE_19 = 50868;
ND_INTERNAL_LINE_20 = 50870;
ND_INTERNAL_LINE_21 = 50872;
ND_INTERNAL_LINE_22 = 50874;
ND_INTERNAL_LINE_23 = 50876;
ND_START_TRIGGER = 51150;
ND_START_TRIGGER_POLARITY = 51151;
ND_COUNTING_SYNCHRONOUS = 51200;
ND_SYNCHRONOUS = 51210;
ND_ASYNCHRONOUS = 51220;
ND_CONFIGURABLE_FILTER = 51230;
ND_ENCODER_TYPE = 51240;
ND_Z_INDEX_ACTIVE = 51250;
ND_Z_INDEX_VALUE = 51260;
ND_SNAPSHOT = 51270;
ND_POSITION_MSR = 51280;
ND_BUFFERED_POSITION_MSR = 51290;
ND_SAVED_COUNT = 51300;
ND_READ_MARK_H_SNAPSHOT = 51310;
ND_READ_MARK_L_SNAPSHOT = 51320;
ND_WRITE_MARK_H_SNAPSHOT = 51330;
ND_WRITE_MARK_L_SNAPSHOT = 51340;
ND_BACKLOG_H_SNAPSHOT = 51350;
ND_BACKLOG_L_SNAPSHOT = 51360;
ND_ARMED_SNAPSHOT = 51370;
ND_EDGE_GATED_FSK = 51371;
ND_SIMPLE_GATED_EVENT_CNT = 51372;
ND_VIDEO_TYPE = 51380;
ND_PAL_B = 51390;
ND_PAL_G = 51400;
ND_PAL_H = 51410;
ND_PAL_I = 51420;
ND_PAL_D = 51430;
ND_PAL_N = 51440;
ND_PAL_M = 51450;
ND_NTSC_M = 51460;
ND_COUNTER_TYPE = 51470;
ND_NI_TIO = 51480;
ND_AM9513 = 51490;
ND_STC = 51500;
ND_8253 = 51510;
ND_A_HIGH_B_HIGH = 51520;
ND_A_HIGH_B_LOW = 51530;
ND_A_LOW_B_HIGH = 51540;
ND_A_LOW_B_LOW = 51550;
ND_Z_INDEX_RELOAD_PHASE = 51560;
ND_UPDOWN_LINE = 51570;
ND_DEFAULT_PFI_LINE = 51580;
ND_BUFFER_SIZE = 51590;
ND_ELEMENT_SIZE = 51600;
ND_NUMBER_GP_COUNTERS = 51610;
ND_BUFFERED_TIME_STAMPING = 51620;
ND_TIME_0_DATA_32 = 51630;
ND_TIME_8_DATA_24 = 51640;
ND_TIME_16_DATA_16 = 51650;
ND_TIME_24_DATA_8 = 51660;
ND_TIME_32_DATA_32 = 51670;
ND_TIME_48_DATA_16 = 51680;
ND_ABSOLUTE = 51690;
ND_RELATIVE = 51700;
ND_TIME_DATA_SIZE = 51710;
ND_TIME_FORMAT = 51720;
ND_HALT_ON_OVERFLOW = 51730;
ND_OVERLAY_RTSI_ON_PFI_LINES = 51740;
ND_STOP_TRIGGER = 51750;
ND_TS_INPUT_MODE = 51760;
ND_BOTH_EDGES = 51770;
ND_CLOCK_0 = 51780;
ND_CLOCK_1 = 51790;
ND_CLOCK_2 = 51800;
ND_CLOCK_3 = 51810;
ND_SYNCHRONIZATION_LINE = 51820;
ND_TRANSFER_METHOD = 51830;
ND_SECONDS = 51840;
ND_PRECISION = 51850;
ND_NANO_SECONDS = 51860;
ND_SYNCHRONIZATION_METHOD = 51870;
ND_PULSE_PER_SECOND = 51880;
ND_IRIG_B = 51890;
ND_SIMPLE_TIME_MSR = 51900;
ND_SINGLE_TIME_MSR = 51910;
ND_BUFFERED_TIME_MSR = 51920;
ND_DMA = 51930;
{ special types }
{ NI-DAQ function prototypes }
function AI_Change_Parameter (
slot: i16;
channel: i16;
paramID: u32;
paramValue: u32
):nidaqStatus; stdcall; external nidaqdll;
function AI_Check (
slot: i16;
status: pi16;
value: pi16
function AI_Clear (
slot: i16
function AI_Configure (
slot: i16;
chan: i16;
inputMode: i16;
inputRange: i16;
polarity: i16;
driveAIS: i16
function AI_Mux_Config (
slot: i16;
numMuxBrds: i16
function AI_Read (
slot: i16;
chan: i16;
gain: i16;
value: pi16
function AI_Setup (
slot: i16;
chan: i16;
gain: i16
function AI_VRead (
slot: i16;
chan: i16;
gain: i16;
volts: pf64
function AI_VScale (
slot: i16;
chan: i16;
gain: i16;
gainAdjust: f64;
offset: f64;
reading: i16;
voltage: pf64
function Align_DMA_Buffer (
slot: i16;
resource: i16;
buffer: pi16;
cnt: u32;
bufSize: u32;
alignIndex: pu32
function AO_Calibrate (
board: i16;
operation: i16;
EEPROMloc: i16
function AO_Configure (
slot: i16;
chan: i16;
outputPolarity: i16;
IntOrExtRef: i16;
refVoltage: f64;
updateMode: i16
function AO_Change_Parameter (
slot: i16;
channel: i16;
paramID: u32;
paramValue: u32
function AO_Update (
slot: i16
function AO_VWrite (
slot: i16;
chan: i16;
voltage: f64
function AO_Write (
slot: i16;
chan: i16;
value: i16
function Calibrate_E_Series (
deviceNumber: i16;
calOp: u32;
setOfCalConst: u32;
calRefVolts: f64
function Calibrate_59xx (
deviceNumber: i16;
operation: u32;
refVoltage: f64
function Calibrate_DSA (
deviceNumber: i16;
operation: u32;
refVoltage: f64
function Config_Alarm_Deadband (
slot: i16;
mode: i16;
chanStr: pi8;
trigLvl: f64;
deadbandWidth: f64;
handle: HWND;
alarmOnMsg: i16;
alarmOffMsg: i16;
callbackAddr: u32
function Config_ATrig_Event_Message (
slot: i16;
mode: i16;
chanStr: pi8;
trigLvl: f64;
winSize: f64;
trigSlope: i16;
skipCnt: u32;
preTrigScans: u32;
postTrigScans: u32;
handle: HWND;
msg: i16;
callBackAddr: u32
function Config_DAQ_Event_Message (
slot: i16;
mode: i16;
chanStr: pi8;
DAQEvent: i16;
trigVal0: i32;
trigVal1: i32;
skipCnt: u32;
preTrigScans: u32;
postTrigScans: u32;
handle: HWND;
msg: i16;
callBackAddr: u32
function Configure_HW_Analog_Trigger (
deviceNumber: i16;
onOrOff: u32;
lowValue: i32;
highValue: i32;
mode: u32;
trigSource: u32
function CTR_Config (
slot: i16;
ctr: i16;
edgeMode: i16;
gateMode: i16;
outType: i16;
outPolarity: i16
function CTR_EvCount (
slot: i16;
ctr: i16;
timebase: i16;
cont: i16
function CTR_EvRead (
slot: i16;
ctr: i16;
overflow: pi16;
counts: pu16
function CTR_FOUT_Config (
slot: i16;
FOUT: i16;
mode: i16;
timebase: i16;
division: i16
function CTR_Period (
slot: i16;
ctr: i16;
timebase: i16
function CTR_Pulse (
slot: i16;
ctr: i16;
timebase: i16;
delay: u16;
pulseWidth: u16
function CTR_Rate (
freq: f64;
duty: f64;
timebase: pi16;
period1: pu16;
period2: pu16
function CTR_Reset (
slot: i16;
ctr: i16;
outState: i16
function CTR_Restart (
slot: i16;
ctr: i16
function CTR_Simul_Op (
slot: i16;
numCtrs: i16;
ctrList: pi16;
mode: i16
function CTR_Square (
slot: i16;
ctr: i16;
timebase: i16;
period1: u16;
period2: u16
function CTR_State (
slot: i16;
ctr: i16;
outState: pi16
function CTR_Stop (
slot: i16;
ctr: i16
function DAQ_Check (
slot: i16;
progress: pi16;
retrieved: pu32
function DAQ_Clear (
slot: i16
function DAQ_Config (
slot: i16;
startTrig: i16;
extConv: i16
function DAQ_DB_Config (
slot: i16;
dbMode: i16
function DAQ_DB_HalfReady (
slot: i16;
halfReady: pi16;
status: pi16
function DAQ_DB_Transfer (
slot: i16;
hbuffer: pi16;
ptsTfr: pu32;
status: pi16
function DAQ_Monitor (
slot: i16;
chan: i16;
seq: i16;
monitorCnt: u32;
monitorBuf: pi16;
newestIndex: pu32;
status: pi16
function DAQ_Op (
slot: i16;
chan: i16;
gain: i16;
buffer: pi16;
cnt: u32;
sampleRate: f64
function DAQ_Rate (
rate: f64;
units: i16;
timebase: pi16;
sampleInt: pu16
function DAQ_Start (
slot: i16;
chan: i16;
gain: i16;
buffer: pi16;
cnt: u32;
timebase: i16;
sampInt: u16
function DAQ_StopTrigger_Config (
slot: i16;
preTrig: i16;
preTrigCnt: u32
function DAQ_to_Disk (
slot: i16;
chan: i16;
gain: i16;
fileName: pi8;
cnt: u32;
sampleRate: f64;
concat: i16
function DAQ_VScale (
slot: i16;
chan: i16;
gain: i16;
gainAdjust: f64;
offset: f64;
cnt: u32;
binArray: pi16;
voltArray: pf64
function DIG_Block_Check (
slot: i16;
grp: i16;
remaining: pu32
function DIG_Block_Clear (
slot: i16;
grp: i16
function DIG_Block_In (
slot: i16;
grp: i16;
buffer: pi16;
cnt: u32
function DIG_Block_Out (
slot: i16;
grp: i16;
buffer: pi16;
cnt: u32
function DIG_Block_PG_Config (
slot: i16;
grp: i16;
PGmode: i16;
reqSource: i16;
timebase: i16;
interval: u16;
externalGate: i16
function DIG_DB_Config (
slot: i16;
grp: i16;
DBMode: i16;
oldDataStop: i16;
partialTransfer: i16
function DIG_DB_HalfReady (
slot: i16;
grp: i16;
halfReady: pi16
function DIG_DB_Transfer (
slot: i16;
grp: i16;
halfBuffer: pi16;
ptsTfr: u32
function DIG_Grp_Config (
slot: i16;
grp: i16;
grpsize: i16;
port: i16;
direction: i16
function DIG_Grp_Mode (
slot: i16;
grp: i16;
sigType: i16;
edge: i16;
reqpol: i16;
ackpol: i16;
settleTime: i16
function DIG_Grp_Status (
slot: i16;
grp: i16;
status: pi16
function DIG_In_Grp (
slot: i16;
grp: i16;
grp_pat: pi16
function DIG_In_Line (
slot: i16;
port: i16;
linenum: i16;
state: pi16
function DIG_In_Port (
slot: i16;
port: i16;
pattern: pi16
function DIG_Line_Config (
slot: i16;
port: i16;
linenum: i16;
direction: i16
function DIG_Out_Grp (
slot: i16;
grp: i16;
grp_pat: i16
function DIG_Out_Line (
slot: i16;
port: i16;
linenum: i16;
state: i16
function DIG_Out_Port (
slot: i16;
port: i16;
pattern: i16
function DIG_Prt_Config (
slot: i16;
port: i16;
latch_mode: i16;
direction: i16
function DIG_Prt_Status (
slot: i16;
port: i16;
status: pi16
function DIG_SCAN_Setup (
slot: i16;
grp: i16;
numPorts: i16;
portList: pi16;
direction: i16
function Get_DAQ_Device_Info (
deviceNumber: i16;
infoType: u32;
infoVal: pu32
function Get_DAQ_Event (
timeOut: u32;
handle: pi16;
msg: pi16;
wParam: pi16;
lParam: pi32
function Get_NI_DAQ_Version (
version: pu32
function GPCTR_Config_Buffer (
deviceNumber: i16;
gpCounterNumber: u32;
reserved: u32;
numPoints: u32;
buffer: pu32
function GPCTR_Read_Buffer (
deviceNumber: i16;
readMode: u32;
readOffset: i32;
numPointsToRead: u32;
timeOut: f64;
numPointsRead: pu32;
buffer: pu32
function Line_Change_Attribute (
deviceNumber: i16;
lineNumber: u32;
attribID: u32;
attribValue: u32
function GPCTR_Control (
deviceNumber: i16;
action: u32
function GPCTR_Set_Application (
deviceNumber: i16;
application: u32
function GPCTR_Watch (
deviceNumber: i16;
watchID: u32;
watchValue: pu32
function ICTR_Read (
slot: i16;
counter: i16;
cnt: pu16
function ICTR_Reset (
slot: i16;
counter: i16;
state: i16
function ICTR_Setup (
slot: i16;
counter: i16;
mode: i16;
cnt: u16;
binBCD: i16
function Init_DA_Brds (
slot: i16;
brdCode: pi16
function Lab_ISCAN_Check (
slot: i16;
status: pi16;
retrieved: pu32;
finalScanOrder: pi16
function Lab_ISCAN_Op (
slot: i16;
numChans: i16;
gain: i16;
buffer: pi16;
cnt: u32;
sampleRate: f64;
scanRate: f64;
function Lab_ISCAN_Start (
slot: i16;
numChans: i16;
gain: i16;
buffer: pi16;
cnt: u32;
timebase: i16;
sampleInt: u16;
scanInt: u16
function Lab_ISCAN_to_Disk (
slot: i16;
numChans: i16;
gain: i16;
fileName: pi8;
cnt: u32;
sampleRate: f64;
scanRate: f64;
concat: i16
function LPM16_Calibrate (
slot: i16
function MIO_Config (
slot: i16;
dither: i16;
useAMUX: i16
function Peek_DAQ_Event (
timeOut: u32;
handle: pi16;
msg: pi16;
wParam: pi16;
lParam: pi32
function REG_Level_Read (
slot: i16;
registerIndex: i16;
registerValue: pu32
function REG_Level_Write (
slot: i16;
registerIndex: i16;
bitsAffected: u32;
bitSettings: u32;
registerValue: pu32
function RTSI_Clear (
slot: i16
function RTSI_Clock (
slot: i16;
connect: i16;
direction: i16
function RTSI_Conn (
slot: i16;
brdSignal: i16;
busLine: i16;
direction: i16
function RTSI_DisConn (
slot: i16;
brdSignal: i16;
busLine: i16
function SC_2040_Config (
deviceNumber: i16;
channel: i16;
sc2040Gain: i16
function SCAN_Demux (
buffer: pi16;
cnt: u32;
numChans: i16;
muxMode: i16
function SCAN_Op (
slot: i16;
numChans: i16;
chans: pi16;
gains: pi16;
buffer: pi16;
cnt: u32;
sampleRate: f64;
scanRate: f64
function SCAN_Sequence_Demux (
numChans: i16;
chanVector: pi16;
bufferSize: u32;
buffer: pi16;
samplesPerSequence: i16;
scanSequenceVector: pi16;
samplesPerChanVector: pu32
function SCAN_Sequence_Retrieve (
deviceNumber: i16;
function SCAN_Sequence_Setup (
deviceNumber: i16;
numChans: i16;
chanVector: pi16;
gainVector: pi16;
scanRateDivVector: pi16;
scansPerSequence: pi16;
samplesPerSequence: pi16
function SCAN_Setup (
slot: i16;
num_chans: i16;
chans: pi16;
gains: pi16
function SCAN_Start (
slot: i16;
buffer: pi16;
cnt: u32;
tb1: i16;
si1: u16;
tb2: i16;
si2: u16
function SCAN_to_Disk (
slot: i16;
numChans: i16;
chans: pi16;
gains: pi16;
fileName: pi8;
cnt: u32;
sampleRate: f64;
scanRate: f64;
concat: i16
function Select_Signal (
deviceNumber: i16;
signal: u32;
source: u32;
sourceSpec: u32
function Set_DAQ_Device_Info (
deviceNumber: i16;
infoType: u32;
infoVal: u32
function Timeout_Config (
slot: i16;
numTicks: i32
function WFM_Chan_Control (
slot: i16;
channel: i16;
operation: i16
function WFM_Check (
slot: i16;
channel: i16;
progress: pi16;
itersDone: pu32;
pointsDone: pu32
function WFM_ClockRate (
slot: i16;
group: i16;
whickClock: i16;
timebase: i16;
updateInterval: u32;
mode: i16
function WFM_DB_Config (
slot: i16;
numChans: i16;
chanVect: pi16;
DBMode: i16;
oldDataStop: i16;
function WFM_DB_HalfReady (
slot: i16;
numChans: i16;
chanVect: pi16;
halfReady: pi16
function WFM_DB_Transfer (
slot: i16;
numChans: i16;
chanVect: pi16;
buffer: pi16;
cnt: u32
function WFM_from_Disk (
slot: i16;
numChans: i16;
chanVect: pi16;
fileName: pi8;
startPts: u32;
endPts: u32;
iterations: u32;
rate: f64
function WFM_Group_Control (
slot: i16;
group: i16;
operation: i16
function WFM_Group_Setup (
slot: i16;
numChans: i16;
chanVect: pi16;
group: i16
function WFM_Load (
slot: i16;
numChans: i16;
chanVect: pi16;
buffer: pi16;
cnt: u32;
iterations: u32;
mode: i16
function WFM_Op (
slot: i16;
numChans: i16;
chanVect: pi16;
buffer: pi16;
cnt: u32;
iterations: u32;
rate: f64
function WFM_Rate (
rate: f64;
units: i16;
timebase: pi16;
updateInterval: pu32
function WFM_Scale (
slot: i16;
chan: i16;
cnt: u32;
gain: f64;
voltArray: pf64;
binArray: pi16
function AI_Read_Scan (
slot: i16;
reading: pi16
function AI_VRead_Scan (
slot: i16;
reading: pf64
function SCXI_ModuleID_Read (
scxiID: i16;
moduleSlot: i16;
function USE_E_Series
function USE_E_Series_AI
function USE_E_Series_AO
function USE_E_Series_DIO
function USE_E_Series_GPCTR
function USE_E_Series_GPCTR_Simple
function USE_E_Series_Misc
function USE_E_Series_WFM
function AO_VScale (
slot: i16;
chan: i16;
voltage: f64;
value: pi16
function GPCTR_Change_Parameter (
deviceNumber: i16;
paramID: u32;
paramValue: u32
function USE_E_Series_DAQ
function USE_MIO
function USE_LPM
function USE_LAB
function USE_DIO_96
function USE_DIO_32F
function USE_DIO_24
function USE_AO_610
function USE_AO_2DC
function DIG_Trigger_Config (
slot: i16;
grp: i16;
startTrig: i16;
startPol: i16;
stopTrig: i16;
stopPol: i16;
ptsAfterStopTrig: u32;
pattern: u32;
patternMask: u32
function SCXI_Set_Threshold (
chassisID: i16;
moduleSlot: i16;
channel: i16;
threshHold: f64;
hysteresis: f64
function WFM_Set_Clock (
slot: i16;
group: i16;
whichClock: u32;
desiredRate: f64;
units: u32;
actualRate: pf64
function DAQ_Set_Clock (
slot: i16;
whichClock: u32;
desiredRate: f64;
units: u32;
actualRate: pf64
function Tio_Select_Signal (
deviceNumber: i16;
signal: u32;
source: u32;
sourceSpec: u32
function Tio_Combine_Signals (
deviceNumber: i16;
internalLine: u32;
logicalExpression: u32
function DIG_In_Prt (
slot: i16;
port: i16;
pattern: pi32
function DIG_Out_Prt (
slot: i16;
port: i16;
pattern: i32
function AI_Get_Overloaded_Channels (
deviceNumber: i16;
numChannels: pi16;
channelList: pi16
function Calibrate_TIO (
deviceNumber: i16;
operation: u32;
setOfCalConst: u32;
referenceFreq: f64
function DIG_Change_Message_Config (
deviceNumber: i16;
operation: i16;
riseChanStr: pi8;
fallChanStr: pi8;
handle: HWND;
msg: i16;
callBackAddr: u32
function DIG_Change_Message_Control (
deviceNumber: i16;
ctrlCode: i16
function DIG_Filter_Config (
deviceNumber: i16;
mode: i16;
chanStr: pi8;
interval: f64
implementation
end.
Double buffer Begin VB.Form Form1
' Example Program:
' DAQdoubleBuf.FRM AI
' Description:
' Read a waveform from one analog input channel continuously using
' internal timing (uses low-level NI-DAQ functions)
' Example Task Types:
' BUF, 1CH, CONT, INTTIM, ASYNC, INTTRIG
' List of key parameters:
' iDBmodeON, ulCount, iSampTB, iHalfReady, lTimeout
' List of NI-DAQ Functions used in this example:
' Timeout_Config, NIDAQErrorHandler, DAQ_Rate, DAQ_DB_Config,
' DAQ_Start, DAQ_DB_HalfReady, DAQ_DB_Transfer, NIDAQYield,
' DAQ_Clear
' SUBROUTINE: cmdDoOperation_Click
' DESCRIPTION: The main NI-DAQ operations are here
Sub cmdDoOperation_Click()
Dim iStatus As Integer
Dim iRetVal As Integer
Dim iDevice As Integer
Dim iDBmodeON As Integer
Dim iDBmodeOFF As Integer
Dim iChan As Integer
Dim iGain As Integer
Dim ulCount As Long
Dim iLoopCount As Integer
Dim iHalfBufsToRead As Integer
Dim dSampRate As Double
Dim iUnits As Integer
Dim iSampTB As Integer
Dim uSampInt As Integer
Static piBuffer(1000) As Integer
Static piHalfBuffer(500) As Integer
Dim iHalfReady As Integer
Dim iDAQstopped As Integer
Dim ulPtsTfr As Long
Dim iIgnoreWarning As Integer
Dim lTimeout As Long
Dim iYieldON As Integer
Dim i As Long
iDevice% = 1
iDBmodeON% = 1
iChan% = 1
iGain% = 1
ulCount& = 1000
iHalfBufsToRead% = 20
dSampRate# = 1000.0
lTimeout& = 180
iYieldON% = 1
' This sets a timeout limit (#Sec * 18ticks/Sec) so that if there is
' something wrong, the program won't hang on the DAQ_DB_Transfer
' call.
iStatus% = Timeout_Config(iDevice%, lTimeout&)
iRetVal% = NIDAQErrorHandler(iStatus%, "Timeout_Config", iIgnoreWarning%)
' Convert sample rate (S/sec) to appropriate timebase and sample
' interval values.
iStatus% = DAQ_Rate(dSampRate#, iUnits%, iSampTB%, uSampInt%)
' Turn ON software double-buffered mode.
iStatus% = DAQ_DB_Config(iDevice%, iDBmodeON%)
iRetVal% = NIDAQErrorHandler(iStatus%, "DAQ_DB_Config", iIgnoreWarning%)
' Acquire data indefinitely into circular buffer from a single
' channel. If you want to acquire from multiple channels, use
' SCAN_Start of Lab_ISCAN_Start.
iStatus% = DAQ_Start(iDevice%, iChan%, iGain%, piBuffer%(0), ulCount&, iSampTB%, uSampInt%)
iRetVal% = NIDAQErrorHandler(iStatus%, "DAQ_Start", iIgnoreWarning%)
' Loop until 'iHalfBufsToRead' half buffers are acquired. HINT: You
' can be doing other foreground tasks during this time.
While ((iLoopCount% < iHalfBufsToRead%) And (iStatus% = 0))
iStatus% = DAQ_DB_HalfReady(iDevice%, iHalfReady%, iDAQstopped%)
If ((iHalfReady% = 1) And (iStatus% = 0)) Then
' Grab half-buffer of data into 'piHalfBuffer'. You can
' scale the data with DAQ_VScale, or store it to disk using
' your own file I/O calls.
iStatus% = DAQ_DB_Transfer(iDevice%, piHalfBuffer%(0), ulPtsTfr&, iDAQstopped%)
iRetVal% = NIDAQErrorHandler(iStatus%, "DAQ_DB_Transfer", 0)
iLoopCount = iLoopCount+ 1
Else
iRetVal% = NIDAQErrorHandler(iStatus%, "DAQ_DB_HalfReady", 0)
End If
DoEvents
Wend
' CLEANUP - Don't check for errors on purpose.
iStatus% = DAQ_Clear(iDevice%)
' Set DB mode back to initial state.
iStatus% = DAQ_DB_Config(iDevice%, iDBmodeOFF%)
' Disable timeouts.
iStatus% = Timeout_Config(iDevice%, -1)
End Sub
(4,532 Views)
hi ulrich_VII
thanks for the answer , but are you sure it would work for 6.9.1 and do you know any information about the example application that comes in , the led lighting up one , i just need it to work for more than 5min , the leds to stay lighted up , it flashes a message contact ni for the code , please let me know if there is a way i could get to do that , or do ihave to do the total coding again .
once again thanks for the answer
(4,530 Views)
With the unit you can assess all functions of the nidaq.dll (traditional Nidaq version 6.9.1) for E-Series and other. It works with the 7.0.1-nidaq.dll too (I use it).
The example (from NI) at the end is for Visual Basis
for double buffering AD-input. You can delete it.
You can cut all functions and constants you do not need (I did it partly).
I do not understand you problem. Please explain it (maybe my english is not that good)
(4,530 Views)
hi ulrich_VII
maybe my question was a bit confusing , will explain it clearly
1.in the software installed along with the ni 6.9.1 , already there is an delphi application in the examples section.
the application turns on the digital output lines of the pci 1200 multifunction daq which have been connected to leds , by running the delphi application i can turn on or off the leds .
this delphi application runs only for 5 minutes , after which on the screen the message comes that contact ni for the delphi code to make it run more than 5 min .
just wanted to know if i could find that specific piece of code , or is it that i have to do the programming all by myself again.
anyway thank you for your patient support , please l
et me knowif you know anything about the above.
(4,530 Views)
send me the delphi source code. Maybe I can help you
box@dephix.de
(4,529 Views)
