deployment of .NET NI DAQ application
It doesn't. As I tried to explain, on the dev machine (x64), I've got NIDAQ installed. The dlls are 64bit because automatically installed by the NIDAQ installer. The installer only installs 64bit dlls if 64bit OS is detected during installation of NIDAQ.
When I deploy the exe to the x86 machine, I've got incompatible libraries carried along with the build, IRRESPECTIVE whether I chose x86, x64 or AnyCPU.
Message 11 of 13
(638 Views)
Up
Message 12 of 13
(592 Views)
HI NoNickName3,
You seem to be opening an issue from 4 years ago, could you post a new thread so we can answer your question better?
Thank!
Message 13 of 13
(583 Views)
