detecting a pulse
Iam using a PXI-6722. I have a device which would generate a pulse of 2ms duration based on some conditions. I need to detect this pulse. How can i do this requirement?
I thought of using the counter for detecting this. But i want a vi which would stop execution after detecting the pulse, how can i achieve this.
Regards
Gopal
(2,965 Views)
Use a counter on your DAQ card
You could use 'measure pulse width.vi', which you can find in the examples shipped with LabVIEW
Use this vi as a reference.
You could measure pulse width inside a while loop.
Once you detect the 2mS pulse width, just stop the while loop
(2,962 Views)
