difference between NI 9227 and NI 9203,
can i use with current transformer. what max rating can it get, interm of current and watt. which one is better also.
i want to use 6 channels at one time. need quick and fast data simultainously with synchronization.
can i sold my sensor one board of DAQ.
if anyone has pic. i want to see live pics of both DAQ from different angles. thanks
(4,429 Views)
The product pages for the 9227 and 9203. I'm sorry but I don't understand most of your questions except that you want to capture 6 channels simultaneously. As you can see, the 9227 is a simultaneous capture board but it has only 4 channels. The 9203 has 8 channels but the channels are muxed so you have a small delay between channels.
(4,394 Views)
HI,
i want to know about DAQ, either it has capability to do following task.
1. actually i am using current sensor with DAQ. my current rating will vary from 1 to 3 Amp. i give input as analog and want output as analog.
2. i want to use 6 channels, each 2 channels send data simultainously so each 2 channels should have same clock signal.
3. i also want to know about connectivity of my sensor with DAQ. is it either by normal cable wire by soldiering or i have to use RS 232 wire.
4. what is speed of data with in range of 5 meters. meaning how much time it take to receive process and send data. actually i just use DAQ as medium of wireless...
5. can i also increase RSSI of my DAQ, like if my distance is increased.
(4,357 Views)
