different Daq devices with 64/128 channel with sampling rate of 200 ksps per channel and min 14 bit resolution
I need a Data Acquisition System  system with 128/132 channels (or 64 channels) ,simultaneous sampling at the rate of  200 ksps/ch or more with 500k/1GB memory and PCI/PCI 104 connector.
Also An output board is required with 128 (or 64)  output channels and DAC at 10 mhz with 1 K Memory/Buffer.
Kindly suggest some low cost options.
(3,134 Views)
Kindly suggest some low cost alternatives of NI.
(3,133 Views)
Do you REALLY need Simultaneous sampling or will a DAQ with a built in MUX work?  I only ask because simultaneous sampling greatly increases cost.
(3,107 Views)
Simultaneous sampling is required for 128(or)64 channels
(3,103 Views)
