different Sampling rates for different channels in Analog Input
I would like to acquire data at different sampling rates on different channels say ACH 0, ACH 1 and so on. I have a PCI 6052E board and NI DAQ 6.9.2. Also is it possible to simultaneously perform Analog output on two different channels along with the Analog input? What will be the problems/consequences as far as the system resources are concerned. I am a beginner in this area and would greatly appreciate any help/pointers for my queries.
Thanking you in advance
Deepak
(3,114 Views)
Search the eaxamples that ship with LV.
Theer is one called simultaneous input and output or something like that.
It will get you started.
re: multiple scan rates. This is acoomplished by sampling all channels at the highest rate and throw away the expttra samples you do not need.
Ben
(3,114 Views)
Hi Deepak,
I faced the same problem recently and have found a few routes out. If you've solved yours do inform me how you did it.
As said by Ben you could decimate the samples. Another way around is to re-configure your board for each set of channels. This also works when for some channels you want waveform data while for others it is scaled/binary data.
Best,
Gurdas
gurdas@qagetech.com
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
(3,114 Views)
