different of digitizer ni 5154 with digital osiloscope
I want to buy TDS 1002B digital oscilloscope which it can connect to PC with a GPIB. Also, I see a NI 5154 is a Digitizer/Oscilloscope.
I want to know difference of TDS 1002B digital oscilloscope with NI 5154.
Would you help me please.
Best regards.
(3,846 Views)
You are comparing a scope with a 60 MHz bandwidth (Tek) to a scope with a 1 GHz bandwidth (NI). Sort of like comparing apples to oranges. The USB-5133 might be a more valid comparison to the Tek scope.
p.s. Why would you order the scope with GPIB when it comes with USB?
(3,836 Views)
Thank you for your reply.
I want to know do you prefer TDS2001B or NI Digitizer 5154?
Thank you
(3,832 Views)
They are not comparable as you can tell from the specs so I really don't understand your question. If you only need the bandwidth of 60 MHz, why would you consider a scope with 1 GHz bandwidth, especially considering the cost difference? If you need the 1 GHz bandwidth, then it's silly to consider the Tek scope.
If you want to know whether to choose a traditional scope or a pc based solution, then that is a different question and what to use will depend on a large number of factors. I build or have built, stand alone test systems and do not need a lab scope that will be sitting on some bench. I have usually found the pc based scopes to be more cost effective and with the case of pci/pxi, much faster. With a stand alone test system, I do not need or want a display for an instrument and certainly do not want or need any front panel controls on an instrument.
Before any recomendations can be made, you need to provide a lot of details on the application and how the instrument will be used.
(3,826 Views)
the scope of the work is to monitoring the health of structures online, using wave propagation. we want to generate a wave with a high frequence about 1 MHz, and receive the wave after travelling through the structure. to detect the defect.
(3,813 Views)
