differents channel in the same daq
Hello to all the people,
I use LabVIEW 8.0 and one DAQ NT-6133 (only one) and I use four the DAQ channel for obtain the voltage signal of 4 sensors. I need to use another channel with a different  configuration (different number of samples, rate, trigger) and obtain the signal of one of this sensor. It is possible???
Because I´m trying to do it using the same device and differences devices for the four and the extra channel and I can´t obtain good results.
The idea is that I can obtain the signal of the extra channel a1´ without stopping the other four channel a1,a2,a3,a4 that it to say I want to obtain the signal output of the channel a1´ each few time (with low frequency) and for obtain the Ubias of this sensor but with stop the other 4 device that have another different trigger but I don´t be able to do it with positive results.
If someone can answer any question or say to me how I can try to do it I would be very thankfull
Best regards
Gonzalo De Francisco.
(2,797 Views)
continued here
(2,786 Views)
