diffrent values from daq mx and traditional daq
Im trying to upgrade my vi's to use daq mx instead of the traditional daq but I got somehing mixed up. I get twice the value from daq mx read function compared to the old traditional one. Any one had simular problems? Its on the analog input im trying to read.
(2,893 Views)
Hi Tudor,
Good afternoon and I hope your well today.
I was reading through the forum and noticed you didn't get support at the time of the post, but felt it wasn't too long ok - so maybe if your still having trouble I can help.
I would make sure first of that if your using the same device with both Trad and DAQmx that you remember to reset the device when you switch...
I would then confirm in MAX (measurement and automation explorer) or with a simple LabVIEW (assuming your using LabVIEW) example to test that the Analog input, does it work correctly? If not then it could be an installation issue.
If yes, the its the code as you suspect.  I wonder if you could post an example piece of code showing the issue, and maybe the community (and I) can help you to resolve the issue.
A great resource for learning DAQ is the,
Getting Started with NI-DAQmx: Main Page
http://zone.ni.com/devzone/cda/tut/p/id/5434
Please let me know how I can help further,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,865 Views)
