digital +5V used as ext ref on APFI 0 stability
Anyone used the digital 5V on a multifunction board (PCI-6259) to ext ref the A/O?  My main concern is stability of voltage and AO / Dig ground violation.
Thanks all.
Chris
(3,412 Views)
Accepted by topic author bonnerupc
Hi Chris,
In the manual it states that:
You can use one of the AO <0..3> signals to be the AO reference for a
different AO signal. However, you must externally connect this channel to
APFI 0 or APFI 1.
If you're looking to have programmatic control over your reference this would be a better option.  Will that be an option for your application?
Dustin D
(3,391 Views)
Thanks Dustin,
That solution will work nicely.  Darn 'pesky' manuals; seem to always have an answer in there somewhere.
I'll have to use one of the four AO's of course, but se'la'vie'.
Appreciate your feedback.
Chris
(3,379 Views)
