digital io pins shorted?
i am using ni 6353 daq board. when i probe any two digital io pins with a multimeter, i find very low resistance between them ~50ohms. i am not sure what's wrong. any clue?
(3,117 Views)
Hi niuser_umn,
The digital I/O channels should be isolated from each other with no electrical path. Is the board powered up when you perform this test? has this always been the case or is this a recent development?
James D.
(3,106 Views)
