digital output for device control
We apply the DAQ DT 9801 of DATATRANSLATION for the control of a test center. With the digital output we want to activy a device, for instance a heater. The TTL level activates a relais. At the same time we would like to measure analog signals. If we detect a distortion in the analog signals the device activated with the digital output should be stopped. We are unable to set the digital output high and at the same time doing data-acquisition
Who has a solution?
(2,895 Views)
Hynatec,
this forum deals with NI data acquisition hardware, so maybe you better should ask this type of question in a DT forum or at DT tech support.
Kind regards,
Jochen Klier
(2,872 Views)
