distributing NIDaq software
Hi
I have a NIDAqmx based application which can function without NI hardware present.
Is there a software redistributable which can be supplied with the app so that errors relating to missing DLLs don't occur?
Nirvtek
Message 1 of 8
(5,538 Views)
Accepted by topic author nirvtek
You can install either the full DAQmx or the core runtime of DAQmx. Either one is a couple of clicks away by selecting 'Support' at the top of the page and then searching for the version you want.
Message 2 of 8
(5,536 Views)
Thanks, that answers my question.
Message 3 of 8
(5,532 Views)
Nm. Please ignore this
Message 4 of 8
(5,504 Views)
My C NIdaq-mx based app doesn't run with the core runtime. It complains about DLLs such as nicaiu.dll.
Message 5 of 8
(5,495 Views)
Nirvtek,
Based on the information in this forum post:
http://forums.ni.com/t5/Multifunction-DAQ/Is-there-a-DLL-for-Ni-DAQmx-rather-than-using-the-lib-file...
I think you will need to install DAQmx on the deployment machines. You can't distribute the DLL by itself with your application.
Kelsey Johnson
Message 6 of 8
(5,466 Views)
Thanks for that. The Daqmx installer  is over a gig in size. Is it legal to distribute the daqmx installer with my app?
Message 7 of 8
(5,460 Views)
Sure! It's freely available on ni.com, so I don't see why it would be a problem.
Message 8 of 8
(5,445 Views)
