does someone have a driver for kloehn pumps
Thanks for youe share
Could you send a copy to me?
My Email: yingzhukite@gmail.com
Message 11 of 19
(2,795 Views)
Here is the Kloehn V6 driver file.
I never used this file, so cannot help you with it.  I ended up using a serial interface and using Kloehn commands through VISA.  If you want example files on this, I will be happy to supply some.
Message 12 of 19
(2,787 Views)
Thanks a lot
Message 13 of 19
(2,771 Views)
I am also (HIGHLY!) interested in any Kloehn V6 syringe pump drivers out there myself.
I am aware this is an old thread but I am willing to wait 🙂
Message 14 of 19
(2,623 Views)
Hi folks... sorry to bring back this old thread... but for those with similar problems using recent versions of Labview...
I have some files for this online here:
https://drive.google.com/?authuser=0#folders/0Bw_dE1twlSIIM0t0TTRaNkZLS2M
Look for "Kloehn Comm.vi" and "Kloehn Status Interpreter.vi."  No promises that they will work for your application!
If you are looking for a drop-down menu of possible commands, you can use the "Kloehn Ombudsman" portion of "pHsys control LEA.vi."  (just ignore or delete the rest of the code).  Click "ask" if you just need to know Kloehn settings and "tell" if you want to change pump settings or issue a command.
The equivalent code for a Cavro syringe pump is in that same file tree.. just go up one level and poke around.
Message 15 of 19
(1,930 Views)
The link does not appear to give the info that you intended.
But thanks anyway.
Message 16 of 19
(1,908 Views)
I'm not sure why that link didn't work, but I'll need to figure it out since I'm sharing these files with some coworkers.  It works for me, so it's probably an issue with accounts.  Any luck with this one?
https://drive.google.com/folderview?id=0Bw_dE1twlSIIM0t0TTRaNkZLS2M&usp=drive_web
A warning that the "ombudsman" bit I mentioned might be currently configured for a Cavro Pump.  The Kloehn Comm and the Kloehn Status Interpreter should work however, provided you send the correct commands.
If you're very new to Kloehn pumps, be sure to send an initialization command after powering up and before issuing fill/dispense commands (and after making sure that the initialization pump movements aren't going to break anything!).
Message 17 of 19
(1,905 Views)
even if it is an hold thread, it looks like people are interested in them...
After several years of experience using them,  you do not need to consider just drivers... but depnding on what you want to do, there is a way to do it.
If you are interested in having some help, maybe you could send me an email and we could discuss maybe some collaboration.
Regards.
P. C.
Message 18 of 19
(1,894 Views)
I'd love to take a look at your driver also. I am going to attempt to automate a Multichannel V6 and it sounds like your work could help me along. Any help would be much appreciated! My email is generalinfo@pressenter.com
Thanks!
jim c
Message 19 of 19
(1,795 Views)
