does usb Multifunc daq 6361 not automatically detect SCXI chassis/accessories
does usb Multifunc daq 6361 not automatically detect SCXI chassis and accessories?
(4,322 Views)
Accepted by topic author kdCMC
Hello kdCMC,
As far as I know only the SCXI-1600 USB Module is able to autodetect SCXI Modules.
This is also mentioned on page 11-12 of the following SCXI Getting Started document:
http://www.ni.com/pdf/manuals/373236m.pdf
All the DAQ devices (including USB-variants like the NI USB-6361) have only an 68-pin shielded (IO) cable between the DAQ device and the SCXI chassis.
This cable does not provide possibilities for auto-detection since it basically just "transfers digital and analog signals" between SCXI chassis and DAQ device.
Is there a specific document that created confusion concerning this?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,263 Views)
