double buffer AI, integer, multi channel, C
Has anybody C or pascal code for AI with a flxible chanallist, fixed frequency, integer Buffer, multi channe for daqmx
The old Code with nidaq was: (Pascal, Delphi 7):
pchans:=@chan_p[0];
   pgains:=@gain_p[0];
   status_ni:=SCAN_Setup (device, nchani16, pchans, pgains);
s_TB2:=0; s_int2:=0;
   status_ni := SCAN_Start (device, pbuffer, count, s_TB, s_int,  s_TB2, s_int2);
  While ((LoopCount < countloop) And (status_ni =  0))do
  begin
    status_ni := DAQ_DB_HalfReady(Device, pHalfReady, pDAQstopped);
    If ((HalfReady =  1) And (status_ni =  0)) Then
    begin
      status_ni := DAQ_DB_Transfer(Device,pBuffer_H,panz_t,pDAQstopped);
      if speichern then BlockWrite(f1, buffer_h[0], count, i);
      inc(LoopCount);
    end;  // halfready
Message 1 of 1
(3,855 Views)
