driver support for legacy hardware
I am trying to use an ancient DAQPad-6507 for an application because I need >48-bit I/O and this outdated device is the only suitable hardware I have.  My computer, on the other hand, is much newer and is running Windows 7.  Does a suitable daq driver exist? This looks like it should do the trick but fails to install because it isn't actually supported by my OS. Traditional NI-DAQ (legacy) 7.5 beta
Thanks for your help!
(3,136 Views)
Hi PTARlab,
I would suggest getting a newer DAQ product, such as the USB-6509. If this is not an option for you, then there are drivers available for older versions of Windows, including Windows XP. If you have a computer with XP on it, you can download the TDAQ driver from the link below.
Traditional NI-DAQ (Legacy) 7.4.4: http://joule.ni.com/nidu/cds/view/p/id/570/lang/en
Jason D
(3,112 Views)
