druck differential pressure sensor
Hi. All,
I just got two legacy Druck differential pressure sensors, model PTX 4170-8989 and PTX 2170-8988.
They are all 4-20mA signal output with a DIN 43650 connector.
I'm trying to connect them into my daq system. But I could not find any spec or manual after googling.
Usually pin 1 is for power supply positive, maybe between 9v-30v. But I have know idea about others pins.
Can someone know the wiring information for them?
Will I screw up them if I get a wrong connections?
Thanks a lot.
Roger
(3,310 Views)
I would advise obtaining the proper specs for your sensors before making any connections. I saw several PXT model Druck products on the GE website, I would recommend inquiring with GE for product information.
Ali M
(3,284 Views)
