duty cycle and period time measurement
i have to measure period time and duty cycle of a pw-signal. Intention is to measure the signal and read out the buffer continuously.
I'm using ctr0 for input the signal to the card (NI PCI-6229). Is a counterpart function to DAQmxCreateCOPulseChanFreq existing with which i could measure the two values?
Actually i try it with DAQmxCreateSemiPeriodChan. Problem is that i have to ensure starting with rising edge for example. But how could i do this?
Thanks for every idea
Andreas
(2,883 Views)
Here some examples:
Duty Cycle Measurement:
http://zone.ni.com/devzone/cda/epd/p/id/2592
Triggered counter measurements:
http://zone.ni.com/devzone/cda/epd/p/id/2410
With a M series card (PCI-6229) you can use the arm start trigger to arm the counter.
http://digital.ni.com/public.nsf/allkb/A00D601140D0F8EC86256F8D007C53F9?OpenDocument
Best regards
Ken
(2,863 Views)
