e-series master timebase
Dear All,
I try to synch to PCI-MIO-16E-1 cards, I connected them with RTSI cable which is configured in MAX. I checked RTSI cable, no shorts nor opens.
Here is code :
    DAQmxErrChk(DAQmxCreateTask("MuxTask1",&hMux1)); //master - voltage
    DAQmxErrChk(DAQmxCreateAIVoltageChan (hMux1, "DAQ_A3/ai0", "", DAQmx_Val_Diff, -5.0, 5.0, DAQmx_Val_Volts, ""));
    DAQmxErrChk(DAQmxCfgSampClkTiming(hMux1,"",reqSampRatePerChan,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,reqSampPerChan));
    DAQmxErrChk (DAQmxCfgAnlgEdgeStartTrig (hMux1, "DAQ_A3/ai0", DAQmx_Val_RisingSlope, 2.0));
    DAQmxErrChk(DAQmxCreateTask("MuxTask2",&hMux2)); //slave - current
    DAQmxErrChk(DAQmxCreateAIVoltageChan (hMux2, "DAQ_A4/ai0", "", DAQmx_Val_Diff, -5.0, 5.0, DAQmx_Val_Volts, ""));
    DAQmxErrChk(DAQmxCfgSampClkTiming(hMux2,"",reqSampRatePerChan,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,reqSampPerChan));
    /* MasterTimebas synch
                 DAQmxErrChk (DAQmxGetTimingAttribute(hMux1,DAQmx_MasterTimebase_Src,strzChanList,1024));
                 DAQmxErrChk (DAQmxGetTimingAttribute(hMux1,DAQmx_MasterTimebase_Rate,&clkRate));
                 DAQmxErrChk (DAQmxSetTimingAttribute(hMux2,DAQmx_MasterTimebase_Src,strzChanList));
                 DAQmxErrChk (DAQmxSetTimingAttribute(hMux2,DAQmx_MasterTimebase_Rate,clkRate));
    //trigger synch
    DAQmxErrChk (DAQmxCfgDigEdgeStartTrig(hMux2,/DAQ_A3/ai/StartTrigger,DAQmx_Val_Rising));
    DAQmxErrChk(DAQmxStartTask(hMux2)); //slave
    DAQmxErrChk(DAQmxStartTask(hMux1)); //master
    DAQmxErrChk(DAQmxWaitUntilTaskDone(hMux1, 1.5));
    DAQmxErrChk(DAQmxWaitUntilTaskDone(hMux2, 1.5));
    DAQmxErrChk(DAQmxReadAnalogF64 (hMux1, reqSampPerChan, 10.0, DAQmx_Val_GroupByScanNumber, muxData1,
                     (reqSampPerChan*numOfChan), &readSampPerChan, NULL));
    DAQmxErrChk(DAQmxReadAnalogF64 (hMux2, reqSampPerChan, 10.0, DAQmx_Val_GroupByScanNumber, muxData2,
    DAQmxStopTask(hMux1) ;
    DAQmxStopTask(hMux2) ;
Everything works fine, DAQ_A3 triggers DAQ_A4, but clocks are not shared.
Now if I unhash part with master timebase synch, I get following error:
Wait Until Done did not indicate that task was done within the specified timeout.
Increas the timeout, check program, and make sure connections for external timing and triggering are in place.
Status Code : -200560.
(3,406 Views)
Dear mpankau,
  First of all I would try to change the lenght of the char array You use as a variable to store the Master Timebase source from 1024 to 256.
char  strzChanList[256];
 DAQmxErrChk (DAQmxGetTimingAttribute(hMux1,DAQmx_MasterTimebase_Src,strzChanList,256));
This is a small change and but for the first sight I couldn't see anything that is incorrect in Your code.
Please make the changes and let me know about the results so we can move forward if needed!
David Varga
NIH
(3,384 Views)
