e6024
I am trying to configure a E6024 and amux 64T card so that channel 1 is + or - 0.5 v (for cold junction compensation) and the rest of the channels have sufficent resolution to accurately read thermocouples.
I am current using labview 6 and have tried the command structure given in the manuals. What appears to be happening is that all of the channels default to the range setting on channel 0 leading to a lack of resolution on the remaining channels. When I introduce a voltage via a millivolt source, this seems to suggest that the range setting is too wide ( the card will read a voltage range far wider than that set when configured via VIs  in Labview)
Does anyone know of an examples of code that shows how to configure the card correctly?
SJH
(2,930 Views)
LabVIEW 6 had only Traditional DAQ support.
Are you using the 'AI Hardware Config' function to set the range of individual channel??
take a look at atttached pic to know where to find it on functions palette.
use the context help in LabVIEW, to understand how to use it
(2,918 Views)
